z stage hangs
Dim3nsioneer
Posted · z stage hangs
After chasing irregular horizontal lines appearing in my prints for over a week I think I finally found the cause. I accidentally watched the z stage as it was jammed at one layer and suddenly dropped leaving a layer with massive underextrusion.
Jamming was possible as I used a flexible coupling (which was unfortunately also flexible in z direction).
For the time being I remounted the original Ultimaker coupling which makes sure there are no such lines. However, the z wobble increase a bit... :sad:
As other people had similar issues with their Ultimaker Originals, I would like for advice how to avoid jamming of the z stage. Are there e.g. any known issues with the linear bearings?
    Aha,
    similar opinions I see.
    Z stage hangs, what I thought....
    See the roll of Lead, between the lexan and the wooden logo plate.
    Not a scientific solution but it works :cool: For a couple of months already..
    WP 000733
