I've PM'd you a link. what i've been seeing on test prints is two layers that don't quite bond together. The material i have is from Technology Outlet in the UK, and is their 'premium flexible filament', with no more information available than that. last night I was able to get such a print to rotate on the pulleys at full speed (linear speed is about 40 inches/sec), so a single layer, if I can manage it, would be ideal, as long as the posts work. I have a feeling I may have to find an alternative solution for them though
If the material is flexible, it will almost certainly be be too stretchy for a precision drive belt.
You may be right. the belt is under no tension, and i'm not expecting the load to be sufficient to cause it to stretch, but when it costs nothing to print a new one, I'm not too concerned. I have a 1kg roll of this stuff, and no other use for it. There will be a small amount of demand, so I might print them and give them away.
burtoogle 509
Could you please post a sample stl file that uses the same teeth profile? Thanks.
