installing Cura
Retiredtech
Posted · installing Cura
Ok I haven't used my printer for a few months. It is not an Utilmaker but I always used Cura before on win 7. Have recently went to a newer computer, Windows 10 pro.
I can't get any version of Cura to complete the install and always get the same message. I have downloaded the latest Python...  Would appreciate any help..
Garry
    Your Cura is having trouble opening from the application package; having a problem to open the start. Try opening your firewall. I'm not a coder, so I don't really know what's going on, actually, but hope this might help.
    I think there's a clue in the last lines shown in the error message above. It's got some permission error trying to open a log file. Please make sure that the AppData\Roaming folder exists for that user and it is writable.
    That didn't help I had tried looking at the fire wall and even turning it off.
    Thankks
    Posted (edited) · installing Cura
    5 hours ago, burtoogle said:
    I think there's a clue in the last lines shown in the error message above. It's got some permission error trying to open a log file. Please make sure that the exists for that user and it is writable.
    It is there and has logs in it.
    But they seem from an earlier install
    Thanks May be some help
    Edited by Retiredtech
    Try removing the stdout.log file (but keep the folder in place).
    Thanks I'll give it a try.. I just went through all the windows stuff today and is says all my files are fine for the system files.
    Well actually I deleted the whole Cura folder in AppData\Roaming folder. As This was a new install after uninstalling everything I decided there should not be any Cura stranglers.  Worked a charm so thanks....
