UM3E 5.2.11 and the latest Cura
FHolzknecht
Posted · UM3E 5.2.11 and the latest Cura
Hello,
I am using an Ultimaker 3 Extended with Bondtech Feeders (and therefore modified feeding speeds) on FW 5.2.11 with cura 4.6.1.
However, if i want to start my print within cura, it tells me that i need to upgrade my printers firmware. The latest FW however is 5.2.11, which already has been used.
Did I miss an update or might this be related to the bondtech modification?
In the end, i need to start the print via webinterface over IP or directly at the machine.
I did experience this issue also with cura 4.5 earlier.
