Posted · Is there a way to remove ALL temperature codes from cura g-code?
For some reason v4.6.1 Cura tries to "even out" temperature before starting a print. My firmware controls temps for me. How do i remove ALL temp codes from the g-code?
Deleting each manually is not an option.
    1 hour ago, ahoeben said:
    You could use a Search and replace postprocessing script.
    Care to explain how those work, and maybe copypaste a line for me to work on.
    Go to Extensions -> Post Processing -> Modify Gcode
    Add a Search and Replace script
    Search: M1(40|90|04|09) .*
    keep Replace: empty
    Turn on the "Use Regular Expressions" checkbox
    Save gcode. There are no more M140, M190, M104 or M109 gcodes in it.
