Is the printer still cooling down from before, or is it just always? It may take quite a long time to cool down, depending on the situation, the airflow, and the bed-temp of the previous print.
Or could it be heat transfered from the electronics below, or a nearby heater, or sunlight? Behind a window in the sun, it can easily be 60°C, like in a car.
I would say: in the morning, after being off for the night, measure the temp before switching it on. Then, without printing, measure again after half an hour or an hour. It should still be about room temp, maybe a little bit more. Shut off windows or other heat sources. I think that could give you an idea if the electronics are fried (short circuit or so).
The temperature reads 39 as a baseline, even after a night of cooldown, the room temperature is stable, the printer is not next to a particularly strong heat source or draft.
I've been searching through the forums and it seems this is not an uncommon issues, it seems the connections on the heated bed are usually the culprit.
https://community.ultimaker.com/topic/3436-a-fix-for-ultimaker-2-heated-bed-not-working/page/2/
i'll do a bit more investigation when the new multimeter arrives.
thanks for your help.
geert_2 545
The cooling fan blows cold air onto the model and glass. In my tests this could give a local difference of up to 15°C on the glass plate for small models. This could be a major source of difference, as the sensor is at the bottom of the glass, not the top.
