UM2 : stepper motors not responding.
Posted (edited) · UM2 : stepper motors not responding.
Hello everyone! I am the proud owner of a UM2. I have been using this printer for five years now with very little to no problems at all.
Unfortunately, yesterday morning I switched the printer ON as usual and to my surprise I received a warning message showing a "Z switch broken" error. I kind of knew from the beginning that the switch wasn't the issue. However, just to be sure, I checked the switch on both Pronterface and the multimeter. As expected it works perfectly. Now, after reading a few discussion on this forum I realised that it could be a problem with the stepper motors. So I tried the following:
1. Move every motor (including the extruder) on Pronterface, no response.
2. Check bed and nozzle heater, they work perfectly.
3. Check the voltage across the K1 relay, I get 4.9V between 1-2, 24.5V between 2-NO and 2-C, 0V 2-NC. I hear it clicking. I also added a wire to connect C with NO. Nothing changed.
4. Checked a few TPs. They all show the correct voltage.
5. Reset to factory settings.
6. Uploaded a new firmware.
7. Power cycled the power supply.
You guessed it right, none of them worked. What's next to try? Don't tell me to buy a new board 😢
Thank you!
Fed
Edited by frederics946
    Posted · UM2 : stepper motors not responding.
    Hi @frederics946, thank you for your message. Based on your findings I see no particular reason why your motors stopped working. I think it may be a good idea to contact reseller see if they have any ideas for troubleshooting and otherwise consider replacing it with a new board. Sorry, hope it helps.
    • 3 weeks later...
    Hi @SandervG ! Thanks for the reply, really appreciated! After hours of debugging, it turns out everything was fried: microcontroller and a few drivers. Fortunately, as they say, in all bad stories there is something good. In this case I was lucky to find an incredibly quick and professional board repair service. Aqib was super quick in identifying the problem and he manually replaced all faulty components for a tiny fraction of the board replacement cost.  If anyone in the UK has similar problems, I couldn't recommend his service enough:
    https://www.ebay.co.uk/itm/332980571042
    Thanks to him, I'm back printing!
    Fed
