Hi ultiarjan,
thank you for your reply.
Yes, that's my setup. While I have made some new screenshots I have figured out where my problem is: If i keep the settings under support as in the first picture below (every extruder selection set to Extruder 2) I'll get and infill with PVA made up from triangels (picture 1 of my original post) with a density of 50%.
If I change the infill extruders like on picture 2 below, then Cura will automatically use different settings for the infill (Pattern = Zig Zag, Density = 15% and also some other settings are changed). This give barely no infill with PLA, just an outer shell (picture 2 of my original post). If i revert this settings to match them with the settings for infill with PVA I'll get the full support infill.
I had not expected that the support infill parameters change automatically dependet on extruder/material.
Rainer
1
ultiarjan 1,216
I don't really understand what you say, but just to be sure I'll point out the obvious.... you do get that the settings for the support extruder show when you select the 2th tab?
