18 minutes ago, Cuq said:This is not a Cura issue but a well known situation in FDM technology, have a look to this page for more solution.
Looks like you misunderstood me slightly I'll try and clarify. The layer is not unsupported as that solution presented rather it is alternately supported by a material to which the filament of choice is unable to reliably attach to. This leads to a situation where, if the print is begun over existing structure the part is completely and perfectly formed, however this cannot be achieved if the print starts in the center. The print remains completely supported but not attached in that instance.
Absolutely no changes to the print path are necessary (admittedly improvements could be made but that isn't the focus of this question) as manually correcting the start position such that it occurs over the prior layer is sufficient to solve the issue.
Overhangs in general shouldn't start in mid air, they always start on the piece and then move outwards using the pre-existent material as the base. Cura (and all slicers I've used atleast) seem to do this by default so the capability is presumably built into the software. I'm chasing what I'm hoping is a simple "begin print over prior layer" checkbox or similar setting. It would appear that doesn't exist so an option that would, in a round about manner, cause the desired outcome with minimal impact on the rest of the print is the most likely route.
Edit: typing on a mobile screen at 2am in the morning so please excuse any typos.
Edited by thesoundman000
Cuq 185
https://hackaday.com/2020/05/17/look-ma-no-support-for-my-floating-holes/
