temperature error
Pixgen
Posted · temperature error
Hello to everyone,
I have been using the creality ender 3 pro model with the ultimaker cura engine for a long time.
A strange mistake has begun to occur in recent days. When I slice and start printing with the settings on the screen, the temperature exceeds 200 ° C and starts printing at 220-225 ° C and always continues at this temperature. Rough / erroneous on the surface of the product printed at this temperature.
When I try the prints I have done before, the printing starts when it reaches 200 ° C as it should be. I encounter such an error in the files I make my new slicing.
I deleted the cura configuration folder and reset the settings, I tried the current version of cura and 4.5.0, I deleted the cura and reloaded it, but the result did not change.
I am waiting for your ideas and help.
the video will be added here when uploaded.
    Guest maht
    Can you paste your start g code here please? or share a project file (File > Save as...)
    Posted (edited) · temperature error
    4 minutes ago, maht said:
    Başlangıç g kodunuzu buraya yapıştırabilir misiniz? proje dosyasını paylaşma veya paylaşma (Dosya> Farklı kaydet ...)
    ; Ender 3 Custom Start G-code
    G92 E0 ; Reset Extruder
    G28 ; Home all axes
    G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
    CE3_eriste.gcode
    Edited by Pixgen
    attach to file
