I have an Ender 3 Pro. As you know, Cura has printer configuration preselects. I selected Cura, so it should be configured correctly.
The Ender 3 Pro comes with a 0.4 mm nozzle. I checked the print speed and it's set to 50mm per second. Does that sound correct?
burtoogle 510
That's due to overextrusion, I think. Is your extruder calibrated for the print speed you are using?
