58 minutes ago, SandervG said:Hi, we're sorry to hear that you are struggling to reach the level of accuracy with your Ultimaker that you are looking for. Perhaps it would help if you could share some specific elements that you need help with, instead of 'it is not good and not accurate'.
We have an engineering profile that should give you pretty good results, and plenty of features in Cura that allow you to print outer walls before inner walls, or the other way around. There is horizontal expansion you can use, and speed settings you can optimise for optimal results.
Plenty to configure and I'm sure with the right settings you can reach the accuracy you are looking for.
Yeah sorry about that.. I agree it is not a good start. But I was feeling a bit let down after my few first prints.
The handling of the machine and the startup was close to flawless, so I had really high expectations for the printing results.
Now, I just got the printer less than a week ago, so I guess I'll have to find the right settings.
To answer your questions:
I use PLA tough (Ultimaker).
I used the following settings I have found on an other thread about accuracy (I did left jerks as default) :
Line width: 0.4
Wall thickness: 1.2
Top/Bottom thickness: 1.2
Speeds: 40
Jerks: 30
Horizontal expansion: -0.03
walls: 3
Also I use Engineering profile with 0.1 height.
Now the pieces fit better,
but I still struggle to screw them together.
After I clean the burr line.
What are the right settings for tough PLA for best accuracy ?
Thanks.
Edited by Cloud-Forge
SandervG 1,423
