The Cura line number errors are just internal error checking. If necessary, lines should get resent automatically. So ignore those for now.
Start printing slightly thicker layers - maybe 0.15mm. That'll make it easier to see what is going on, and you'll get results faster.
Then put your temperature up, a lot. I'd start at 230º. That'll help improve the flow of material.
Once you've done that, post some photos so we can see what's going on, and specifically what errors you are having.
IRobertI 502
What is the problem specifically? If you have a picture of the failed print that would help in figuring out what's wrong.
