Ultimaker Community of 3D Printing Experts
Cant connect S5 to digital factory
Posted · Cant connect S5 to digital factory
I have notified the team that works on the printer networking to have a look at this. Hopefully they'll be able to provide more insights.
Chris
    @GLIL I have spoken to some of the engineers in our embedded systems department. They asked me to check with you if your network might be running Active Directory (AD) as domain controller (and DNS) by any chance. We have seen issues with networks that use AD for DNS before (appearently AD has implemented some networking standards incorrectly there, or it caches too much). If you could check that for me that'd be great.
    Chris
    1 minute ago, GLIL said:
    I know for a fact that we do run MS Active Directory!
    Interesting! Could you confirm with your IT admin if they also use AD as DNS server inside the (V)LAN? Also, I got some commands you can run on the printer to verify (if you enable developer mode via the printer setting screen and then SSH into the machine):
    vi ./system/multi-user.target.wants/connman.service
    Inside that file, modify the ExecStart line like this:
    ExecStart=/usr/sbin/connmand -n -o -r -c /var/lib/connman/ultimaker_network.config
    (move the -r to before the -c, this lets the network stack no longer use the LAN DNS proxy)
    systemctl daemon-reload
    systemctl restart connman
    It's also OK if you're not able to do this, just getting confirmation from IT that AD manages your DNS already helps us a lot to confirm the root cause!
    Chris
    They/we do. I did an NSLOOKUP and the DNS server is definitely part of our AD domain. (I would ask our IT folks directly, but they typically aren't too keen on discussing anything specific about the network with anyone not in their department).
    It's worth noting my colleague had attempted setting up Digital Factory as well, but with our U3, and experienced similar issues, so it's not just our S5, which makes it seem more likely to be a network issue. FWIW
    Turns out the SSH/vi stuff is a little bit beyond me...
    Thanks for confirming.
    If the nslookup indicates that AD is involved in DNS I think we have found the issue.
    Ultimaker also runs AD and we experience similar issues under certain circumstances, but this confirmation that it also happens on your AD controlled network helps us to get to the core of the problem.
    I know the embedded software team and our own IT department are looking into this particular issue, so once they have some information I'll be sure to share it with you. This could for example be a guide that explains what to configure in AD to make it work correctly (as I've said before, it currently looks like AD is not adhering to some network standards that our printer assumes are in place).
    Thank you, I appreciate the help and the follow-up on this!
      • Startups, apply for the Forward AM Innovation Award!
        Are you a startup using 3D printing? Perhaps you should continue reading...
        Together with BASF we are launching the Forward AM Innovation Award - the very first global contest for startups developing new applications with 3D printing!
        Why apply?
        The winning startup will receive €100,000 in goods and services*, along with coaching and marketing exposure from top-notch leaders in the industry.
        Who can apply?
        Your startup creates products using Additive Manufacturing, is less than 5 years old, and has less than 50 employees. We are looking for 3D printing applications with a strong focus on innovation, sustainability and scalability.
        Dental aligners, shoes, tools, automotive parts, music instruments, industrial tooling and molding, medical implants, sports equipment, toys, architecture, fashion, construction... all are welcome to join!
        Do you have an innovative, sustainable and scalable idea that leverages the unique possibilities of 3D printing? Then it is time to apply!
        More information can be found here.
        Applications close on March 28th, 2021
        * What does "in goods and services" mean?
        The winner will be able to pick any item from the overall product and service portfolio of the sponsors, e.g. printers, materials, consulting, software... Choose whatever you need to accelerate your startup.
      • New here? Register your Ultimaker for free 3D printer onboarding course
