Hi Keith,
Did you ever manage to fix this? You're the only other person online I've found that's trying to run Cura on a Udoo.
For me Cura ran the first time but then through back a segmentation fault every time after.
I also tried completely removing the Cura installation and starting again but had the same issue which I think points to an opengl issue rather than a problem with Cura (but I could be wrong).
I'd be interested to see if you've made any progress.
I too am a noob.
Daid 301
Cura is using python, wxPython and OpenGL, might be a wxPython or OpenGL bug.
