The gcode seems to all be right, having loaded it into http://gcode.ws/ to check it, its showing all the layers as normal. Even loading it into Cura is showing it all fine.
Have you tired to slice and print another file thats not from the same stl to see if the same error happens?
FoNzY 1
you only see one layer because you have "selected only the last layer". at the bottom you have the progress of the currently selected layer while to select the layer you have to use the bar on the right.thumb.png.03e70708148114109ac7858b980c4c9b.png.54135722be5e9175d8e107cfd9751933.png)
Edited by FoNzYLink to post
Enigma_M4 47
That would have been my answer too, if the problem was only the preview simulation.
But as @Tru7h wrote:
there must be another issue. But unfortunately, I can't imagine what's going wrong here.
Regards
