The program itself isn't difficult to use, the complexity comes in tweaking parameters to suit your prints. To get pointers on the latter I suggest browsing through the forum as there's lots of information on that subject to be found. There is no "ultimate setting" that works for every model, personal experience and reading what has worked for others will get you on the right path.
But yes, go ahead and install it and play around with it. By switching to layer view (top right corner) you can see what the individual layers will look like. You'll also want to switch into "Expert mode" to expose more settings.
Thank you for your response.
So Cura is basically the interface for the actual printer?
I assume in that case you have to use Cura as the final step, regardless of which 3D editing program you use to create the actual design - Cura takes that design and places it into a format that the printer then works from?
IRobertI 520
