an update after having fired up my new cr10s.
Looks like no matter the printer profile, selection of non-generic materials causes all the print profiles to "wipe"....doesn't matter if i choose a default listed material ( i.e. - eSun PLA+ ) or make my own material parameters, the end result is "not supported" constantly displayed and the removal of the quick select slider and default print profiles.
While I respect the multitude of printers out there making it impossible for the Cura devs to accommodate EVERY printer out there, this is not a printer profile issue, that's just how the problem manifests itself. While i can understand these issues if you made a custom material profile, surely selecting default listed materials shouldn't cause these issues ?
Here's hoping a fix comes in a later version of Cura, in the mean time if someone can clarify which version of Cura brought this awful change into to existence so I can work out which earlier version of Cura I need to grab, that would be awesome 😄
Cheers.
ahoeben 2,047
"Not supported" means there are no (supported) premade profile for the combination of printer and material. It does not mean you can't print with the combination. Just set the settings you intend to use and proceed as normal.
Longtoke 25
yup, I understand that but....
That doesn't explain why simply switching from a generic material to say eSun PLA+ ( which is apparently supported as it's in the default material list ) also brings about the removal of the standard default print profiles and quick selection slider. This then requires a completely custom profile to be setup ( going through numerous exhaustive options and settings ) with a persistent "not-supported" message on display and no quick selection slider for profiles being available thereafter. I have tried to make my own profiles and materials, but there is no way to copy across the default profiles and have them retain the same functionality and similarly with material "duplicate" function, the associated profiles disappear bringing about the same problems.
To put it simply - there seems to be missing links between materials and print profiles just because i'm using a non-generic listed material, and there is no way to configure the custom or non-generic but default listed materials with the profiles to ensure the quick select slider and default profiles are still available to use.
Bonus question - when / what changed to make this so convoluted compared to the much earlier version of Cura I was using without issue ?. At this stage I think reverting to the last version before these profile / materials issues came about may well be my easiest fix.
