That's not good. That just speeds things up.
This is called stringing and you shouldn't get any stringing for most filaments including PLA. I find white PLA (and all white filaments) string more than others but I usually get zero stringing.
Settings that affect stringing:
retraction - you want to retract just enough to relieve the pressure without letting any air into the nozzle. Around 4-8mm for bowden printers (more for longer bowdens) and around 2mm for direct driver printers.
Temperature - lower temperature is better - more viscous - less leaking
Nozzle size - smaller nozzles drip less
print speed - higher print speed means higher pressure which means you need more retraction - it's best to just print slower and not mess with retraction
1
saurabhkranti 0
solved it - I reduced the minimum layer time
