Cura hangs on an unresponsive screen. (Tested: 4.5-4.6.2)
Posted
· Cura hangs on an unresponsive screen. (Tested: 4.5-4.6.2)
Maybe the log from cura would be more helpful than the event log.
Also when you first run Cura it installs a lot of files and when you uninstall it those files are not deleted. They are in %appdata%/cura or similar location. If you want a "clean install" all you have to do is exit cura - destroy that folder tree - and rerun Cura. No actual install necessary.
Posted
Thank you,
I was deleting the C:\ProgramFiles\Ultimaker Cura 4.6 folder and I did not see the appdata/cura folder. I deleted this folder and apparently that is where the error was.
Cura works again.
Thank you sir.
1
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
Sculptuspoe 1
Thank you,
Cura works again.
Thank you sir.
