Ironing does not work with Spiralize Outer Contour Enabled
ChaosBlades
Posted · Ironing does not work with Spiralize Outer Contour Enabled
You're right and that is because the model you are slicing is solid and the ironing is failing to detect the topmost bottom layer. I have implemented a workaround that I will submit for possible inclusion in future Cura releases.
    • 2 weeks later...
