Posted · Atomic Filament, USA PETG PRO
Hello all, Post 1.
Thought I would start here since I just completed my first print tonight with what seems like abnormal ease. I can only attribute  the success to either the printer or the filament but based on customer reviews I suspect it's the materials.
So here's the run down
Printer: AnyCubic Mega Zero, Fully stock, No heat bed, No Enclosure www.anycubic.com
Filament: Atomic Filaments, USA, Crystal Clear/Natural PETG PRO, $32.99, 1kg Roll,
   Recomended Settings: Nozzle Temp - 232 to 245C, Bed Temp - 60 to 70C,
File: OWL
Total Print Time 4.5hr
Actual Print Settings: Speed - 45mm, Nozzle Temp - 245C, Fan - 49% (125/255), Flow - 100 (defaut)
The results were nearly perfection after the first 5 minutes. I had a user error on my part which is what caused some minor curling on the initial adhesion layer but after that it was flawless.OwlTest.thumb.jpg.c1353dd5f4d4d2c3bbb489bb6efd1588.jpg
Nice result!
Maybe you should think about a heated bed in the future, I helps a lot when printing with other materials than PLA.
    • 4 weeks later...
    • 3 years later...
    I have boght a feider machines FEIDER X-PRINTER .ANYONE HO HAS TROUBLES WHIT THIS PRINTER , AFTER 10 DAYS THE HEAT BED PCR IS ALREADY BROKEN ,  WHEN I AUTO LEVELING THE PRINTER THE BED DUSSEND HEAT SO I GET A "FATAL ERROR RESTART THE PRINTER " AT THE DISPLAY ;AND IT ISSEND SOLVED WHIT RESTARTING THE PRINTER .ANY SUGGESTIONS PLAESE, , IS THERE A PARAMETER TO CHANGE . HAS ANY ONE THE SOFTWHERE FOR THE PRINTER BORD , TO RE ISTYAAL THE PRINTER BORD . AND I CONNECTED THE PRINTER WHIT A USB C CABLE . BUTH A CANT PRINT DIRECTLY TO  THE PRINTER . EVERYTIME I MUST OPLOAD THE FIE ON THE SD CARD EKECT IT FROMM MY PC AND THEN PUT THE SD ARD IN THE PRINDER AND THEN A CAN PRINT . I CALLED FAIDER MACHINES . A THE D'ONT  GIVE A .... ABOUT MY ORE MY WARRENTY  ; I NOW ENGLISCH BUTH I AM  FROM BELGIUM . AND THERE ISSEND NOW WHERE A MANUAL IN DUTCH AVAILLEBEL . ORE DELEIVERD WHIT THE PRINTER NEDER IS THE BIG PLA ROL INCLUDES AS SHOWN ON THE BOX 20231107_195014.thumb.jpg.c95d408efb72b14cf46adf81f3d27627.jpgPLAESE HELP ME IM 62 AND TILLLEARNIG NEW THINGS 20231024_205933.thumb.jpg.303d130dd3e4ef8123ee123728e2920b.jpg20231118_123504.thumb.jpg.214b6280c7116adc908c6877854c6370.jpgTHANKS
    This thread is not at all the right place for this discussion.
