Posted
(edited)
· Cura does not want to slice thin walls
I still haven’t found any settings or combinations of setting that can slices wall thinner than 0.4mm with the Master @Burtoogle Version. Setting the outer wall line width to 0.2mm does ‘work’ but I don’t want to print my whole model with that setting.Plus, itdoesn’t make the Print thin wall work, the wall is still red on the preview mode when usually thin walls are represented in yellow. I tried to uninstall and re-install Cura master….Same problem.I even tried the 3 differentversions of Cura Master provided in the Burtoogle Dropbox (windows 64).
My Printer is an old Tevo Tarantula with Marlin 2.0.
I’m on Windows 10 64
At this point, I’m starting to think that’s a Printing God’s curse…
Edited by Bassline
Bassline 0
Setting the outer wall line width to 0.2mm does ‘work’ but I don’t want to print my whole model with that setting. Plus, it doesn’t make the Print thin wall work, the wall is still red on the preview mode when usually thin walls are represented in yellow.
I tried to uninstall and re-install Cura master…. Same problem. I even tried the 3 different versions of Cura Master provided in the Burtoogle Dropbox (windows 64).
Edited by BasslineLink to post
