DivingDuck 97
Maybe turn over the part?
A part of the object is not touching the buildplate... redesign, move it down into buildplate or flip it over...
When I rotated the part, it read 180 degrees. However, it seemed to be tilted slightly. I repositioned it and the raft is now normal.
Thank you.
to make it easier when using the rotate option, select the "select face to align to buildplate" option...
Edited by Mari
ahoeben 1,886
In all likeliness, your model does not have a perfectly flat bottom. You can either fix the model, or move it down into the buildplate a little bit (say 0.1 mm)
Edited by ahoebenLink to post
