Small layers at end of print
gauthier
Posted (edited) · Small layers at end of print
When I have a print that finished with very little material per layer, the end often gets botched.
My hypothesis is that layers are printed on top of a layer that did not have time to solidify enough. Does that make sense?
Where is the Cura setting to prevent that from happening?
Edited by gauthier
    Posted · Small layers at end of print
    I prefer to print a dummy "cooling-model" next to the real model. The dummy can be empty, except for the top which should have a less or more complementary print-area as your problem-area, so the total print time per layer stays almost equal. So the nozzle is moved away from the real model while printing the dummy, and the model has time to cool down. The advantage of the dummy is that the print speed and material flow stay constant, and thus the temperature and viscosity of the molten plastic. Disadvantage is that is wastes some filament.
    See the pics below. The first pic shows the problem: the hot nozzle staying on top of the cones, and preventing cooling and solidifying. The second pic shows a hollow dummy (except its top), used in a real design.
        • 6 replies
