I bought a used UM3 a couple of years ago, I can share what I looked at, disclaimer, it was my first UM3 so I may not have caught all that I should, but printer has worked fine, so here goes.
1) If it old enough not to have the NFC holder, then what color are the sliding blocks? They should be black, not white. there was a recall on early versions of these for cracking, replaced free (I believe) by Ultimaker. Not sure if that would apply in this case.
2) Check the hours. If they are high enough, you might obviate the first concern as you'd want to replace belts and blocks anyway.
3) Print cores. These don't last forever. I'd check the underside wiring, the insulating coating can wear through from occasional rubbing over a long time.
4) Abrasive material usage - both feeders and nozzles take a beating from this stuff. Original UM feeders are too soft for stuff like nylon/CF and the UM print cores except for CC red will wear out very quickly. I bought two 3dSolex Hardcores and put in abrasive nozzles, I've had no issues except for the occasional trouble with autolevelling. Likewise, Bondtec hardened feeders, pretty easy retrofit.
5) silcone nozzle shield - this is a consumable, mine only came to me with the one that was installed and it needed changing.
6) Firmware! The older printer may or may not be at the current level. I've run across a number of reports where someone tested a printer with the existing (obsolete) firmware, bought it, brought it home, then did the upgrade and effectively bricked it. If the seller can bring the printer up to standard before you see it, that is a potential problem pre-solved.
How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
JohnInOttawa 104
That's all I've got. Good luck!
John
