You can open a .ufp file in any zip application and extract the gcode file from it. For some zip applications, you may have to rename the file from *.ufp to *.zip.   However, if Cura saves .ufp files instead of .gcode files for your non-Ultimaker printer, that is indicative of a wrong configuration in Cura. When you added your printer, instead of scrolling down the list of predefined printers to select your printer model (or a printer model much like your own), you seem to have selecte
