Hello,
Thank you for your prompt reply.
I'm in Montreal, so I can source an arduino easily, but I think the bad solder is the best lead, because it would explain why by playing with the tightening strength it would go on and off (by bending ever so slightly the PCB).
So, how do I go about testing the solder joints?
If I cannot locate the faulty joint, is there a way to buy just the PCB without the arduino and the stepper drivers? €195 is a bit steep :(
I really appreciate your help!
Yves
gr5 2,069
Sounds like the arduino got damaged somehow. Or maybe a bad solder joint between the arduino and the stepper driver. What country are you in? (please put that in your profile). Here in the USA you can get a new arduino for $20 including shipping. In other words, they are so cheap you might as well have an extra one or two sitting around.
