Z stepper fails after print cancellation
bonelli
Posted · Z stepper fails after print cancellation
Hello,
(print with PC on bay B for head 1, PVA on bay E for head 2)
I have a reproducible problem than happen during the startup process of a print (material loading...) in 2 cases :
- if a manually cancel the print
- if some errors occurs (actually ER56, the PVA breaks somewhere in the MS)
In theses cases, the Z stepper seems to be free, the plate fall down down to the bottom of the printer.
What's happening after this fail:
- reboot the printer (soo long) (thanks to the bad error handling of the UM5)
- happy because PC is still loaded on head 1, no need to reload/reprime it except if the firmware want to unload it
- not happy because the MS detected the wrong material on bay B !!!!
- reboot the printer after removing the spool on bay A (soo long) (thanks to the painfull RFID reader)
- ask the MS for material removal on bay E
- Clean the bay E = power off printer and MS
- print again (seems to be good)
The PVA did beaks at the entry of MS, when the end of filament was just entering in the feeding box behind the printer
