Share your print settings...
Either it’s mechanical, like a bad bearing, lack of oil on the rods,
Or
its print settings set too fast, jerk settings too high.
Or
Jason, thank you for your reply.
I am trying to figure out is reason is hardware or settings, but I can't really see anything clearly in the mechanism to blame hardware, unless I am missing something.
Here are the settings I am using.
Nozzle is 0.4mm
About Jerk speed, I can't see where there is the field to fill numbers, except, enable or disable Jerk control.
The reasons for those over shootings on corners is PRINT SPEED. I reduced it to 20mm/s and it is now ok.
juangiluruguay 0
Bump? Should I place it in another section of this forum?
