Check: Enable Support Interface, Support Z Distance, Support Bottom Distance, Enable Support Floor, Support Floor Distance.
A gap like that will occur when something like Support Floor Distance is set to other than "0". If a support has to be built on a surface of your part, it makes it easier to remove.
GregValiant 1,251
