hhahahaha
When I have car problems I pop the hood and look at the engine, shake my head and then call a real man to fix it...
I will watch some youtube videos on how to solder, and then after I burn down my machine I will likely buy a new one hehe.
Thank you for the help, it is much appreciated!!
One more question, how in the heck do I figure out which wire connects to black and which to red? The new hotend wires are both blue.....
GregValiant 150
Cut the connector off the new hot end and throw it away. Then cut the connector off the old hot end leaving 100mm of wire on the connector. Then solder it onto the wires of the new hot end making sure to get the wire colors right. You can get shrink tube insulation at any hardware store. Make sure to remember to slide pieces of insulation onto the wires before you solder.
Do the same kind of thing with the blue wires (old ends soldered to the new wires). Remember to insulate.
I would advise you to never buy an old motorcycle.
