I didn't want to print the model based on the preview. So I can't say it will print those holes although When i go through each layer in the preview it does show it wont print those areas. I really don't want to do a 2 day print to find those holes in it if I don't need to but if there's a chance it won't show up in the print I'm willing to give it a shot.
It is true I do run the fan on a higher than usual power. I can certainly lower it anywhere between 50-80%.
PETG 230-240 extruder depending on the brand with 80 bed. PLA 200 extruder with 60 bed.
gr5 2,071
Can you show a photo of the print please with the holes?
You want the fan at about half power so I'd play with the menu options and listen to the fan noise and drop it until it is about half as loud and use that as your fan setting.
Also what temperature are you printing the PETG? What temp do you usually print PLA?
