I suspect that you've got a short in the wiring for the heater in the head or the bed... as soon as those start up, the short causes the printer to shut down. I had similar things happen when I shorted the fan leads accidentally - but there shouldn't be any fans starting up at the beginning of the print (the fan on the back of the print head should ALWAYS be on when the printer is powered up - check that it is).
Check the wires going into the back of the bed to make sure they seem secure. Also, pull back the mesh around the wires going into the print head, and look for any loose wires or connectors (there should be one connector unused coming from the electronics under the printer. Everything else should be connected.
Finally, remove the cover over the electronics board under the printer, and check for loose connections there.
gr5 1,876
Try taking a video and looking at the video.
