ums5 & cura network issues
Suffolksails
Posted · ums5 & cura network issues
Is cura really bad over wireless with s5? we have to keep 'adding' s5 to cura to get the profiles and it constantly 'loses' connection, i guess we can drill holes and ethernet...but it sits one side of a internal wall next to router...super frustrating!
    It could be the auto-detection, which is a fickle system (as it depends greatly on the configuration of  your network). You could try to manually connect by IP, in which case the auto-detection system is ignored.
    yes i've tried manully adding the IP still get same error...on mac and windows🤨
    Well, it's little help for you now, but i've increased the timeout on Cura's side a bit. 4.7 has just been released, so it will take +-2 months for the next release.
    You could also try connecting with the cloud. I know it sounds a bit weird, but that connection should be a lot more stable.
    On 8/10/2020 at 4:47 PM, gr5 said:
    Oh wait - I can see that you *do* have the black block on the rod.  Instead it is twisting on the rod.  So there are 2 rods that go through the print head and attach to the 4 sliding blocks.  Are they properly snapped into the sliding blocks?  I guess by now it may be irrelevant as it is worn?
    it disconnects from cloud too lol. doesn't seem very stable at all. only way i can get around it is to keep adding printers..
    In that case is the printer visible/online on the cloud?
    Also; Could you share some logs? There might be something in there that could help me debug the issue.
    yes visable in ultimaker factory...
    sent you log file
    Alright, I'll have a look!
    lol spoke to soon, disconnected from everything again...its happily printing away - says it connected to wireless network etc.
    I think i've found something. A fix is pending review: https://github.com/Ultimaker/Cura/pull/8232
    good news thanks!
