Getting "application error.3xg-(Makerbot Repl 2x)
laheyth
Posted · Getting "application error.3xg-(Makerbot Repl 2x)
Newbie here,
I loaded 4.7, and all seems well.
When I run the slicer, and try to save to memory stick, I get an error box that says ERROR- application /3xg
I went back and made sure I  have loaded the 3xg driver, and now am at a loss as to how to fix this.
I dont find any other references  to this when googling same.
    • 1 month later...
    "Just generate the gcode first (whether in MakerWare or RepG, it doesn't matter).  Then use Repetier-Host to view the gcode "print".  If you like what you see, then convert the gcode to x3g.  It's a single step in RepG (convert an opened gcode file to x3g)." - https://groups.google.com/g/makerbot/c/kPCF31ZHn44?pli=1
