Hi @aag, I don't think this is a sign that the printhead is worn out. Do you have it with the same material often? Which materials are you printing with mostly? You could also turn off the flow sensor if you feel like it is more cumbersome than helpful (but I can imagine that might not be your desired way forward?)
I mostly have tPLA+PVA. Contrary to expectations, it's the tPLA that gives trouble; the PVA is just fine (I dry it regularly). And it's real underextrusion, meaning that turning off the flow sensor will result in a ruined print... 😞
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
SandervG 1,519
