I used PLA+ from Esun. For profile, I use customize setting.
You may need to change the horizontal expansion to a negative value (-0,2mm)
1
On 8/29/2020 at 4:29 AM, dogearn2309 said:For profile, I use customize setting.
Print it again with one of the engineering profiles, these profiles are optimized for dimensional accuracies.
Horizontal expansion could solve the problem, but keep in mind that it will reduce all dimensions.
The key is to print slow with equalized speeds and some other settings, which are all included in the engineering profiles.
1
- 2 weeks later...
Generally, my experience is: print slow, cool, and in thin layers, with a material that does not cause too much blobs and strings (but that still fullfills your other wishes concerning temperature resistance and strength of course).
SandervG 1,505
Hello, which material are you using, and which profile have you used for this print? Have you tried the engineering profile already in Cura?
