On the left of the Cura workspace screen is a toolbar. The bottom tool is "Support Blocker". Select your model and then select Support Blocker. Click somewhere on the model to create a block.
On the lower left there will be a list of the objects on the build plate (oddly enough called the "Object List"). Your new support blocker will be Eraser and additional blocks will be added to the list. You can make them active by selecting them on the list.
When you select the Eraser block you can drag it around or type numbers into the Move tool dialog. You can also scale it separately in all three axis. When it covers the proper section of your model you can also elect to have different settings for the intersection volume between your model and the blocker (it's under "Per Model" settings just above the blocker tool). I found that if I wanted to block support AND infill from an area that I needed two blocks covering the same area with one set to infill and the other set to support. I haven't played with that aspect of Cura a lot though.
Thank you very much for a very thorough explanation. Really appreciate your help & time. I got it to work.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
GregValiant 144
deonholt 0
