CR6-SE side bar
davestea
Posted · CR6-SE side bar
hi -
using:
CR-6 SE
Cura v 4.6 and 4.7
win 10
there is no side panel on left side of window
can't select any object
  (it will slice what is loaded)
how do I get it back
tried reinstalling
tried going back to v4.6
then back to v 4.7
ds
    on the left side there are 4 (or more) "flyout buttons"
    ahhh...  "Tool Options" according to one tutorial on-line.
    For instance rotation and move.
    without that (or more) I can't select anything on the build
    area.  I can load a file and slice it but I have no way to edit the drawing.
    Scanning the ALL3DP tutorial I see many of these tools but I only ever
    saw 4 tools.
    Visually this is what happens:
    I load an STL file - it shows up in the draw area
    I move my mouse cursor to the blue object and
    click on it and nothing happens.  I can  click all
    day - even right click - always nothing.  And
    yes my mouse works as I hear my computer
    give a little click/beep when I press the mouse
    button.
    I originally installed the 4.7 version
    and it worked for a few days.
    Uninstalled and Reinstalled it.  No help, same thing
    uninstalled and loaded 4.4 - same issue.
    uninstalled and reloaded 4.7
    I just started Cura to see if there is anything else I
    can say.  Seems very slow to load.
    ok - don't know what  to say.....
    crapola!  I loaded a file and it worked.
    now it tells me it can't load the file I was using
    I ca n only assume the file is corrupted.
    thank you for your response.
    and sorry for the false alarm
    stay healthy
    ds
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
