No, there is one UM3E stored in the cloud, but that printer is at a different site, furthermore it wasn't even added to this instance of Cura as I wasn't logged in.
In a last resort I've removed all appdata and installed versions of Cura and started fresh with a new 4.7 install. The market place has no added plugins (as it should), after adding ColorFabb and Eastman, they simply don't show up in the materials list. Strange thing is that it used to work in 4.6, I even added a set of my own material profiles, but I noticed prior to updating to 4.7 that the materials where suddenly missing. With a clean install, and deleted data I would expect that it would work.
nallath 843
Do you have an Ultimaker active?
