Speed Settings
tk9851
Posted · Speed Settings
Hello all,
I am having an issue with Cura 4.7, where no matter what speed settings I enter, my projects are sliced to print at 100 mm/s. Has anyone encountered this issue?
Thanks in advance
    OK, I assumed you were trying to push it over 100mm/s.....
    How do you know its staying at 100?
    I would try another slicer, if you have the same results in another slicer, then it is your firmware
    If the other slicer slows it down, then the problem is in the gcode that Cura is producing
    Posted (edited) · Speed Settings
    I have been using Cura with Octoprint. I sliced the stl to an SD card and printed directly from that and was able to verify that it had been sliced at 100 mm/s. I have used Prusa slicer, and did not have that issue, which leads me to believe that it is an issue with my Cura settings, though I haven't been able to find anything that would cause that.
    Edited by tk9851
    Did you sort anything out for the speed settings not making it to the Cr-6 SE? I'm having precisely the same issue and must change speeds manually on the printer.
