now with only 3 bottom layers the whole "friskiness" isnt showing up as high any more as it was before. that means it has to do with too much filament being there in the first couple layers with nowhere to go. but i tried printing it with 95 % flow. and it still did the frisky stuff. so what can i do to stop it from happening?
gr5 1,514
I don't know the answer but the first thing I thought of when you said you've been printing PETG and switching to PLA is "the teflon part". I don't even know if you have teflon in your hot end but when you print a lot of higher temp materials and switch to PLA one often finds that the teflon part got soft and deformed and causes lots of problems (typically underextrusion but also possibly variable extrusion: stick/slip).
Cura sometimes prints slower on the lower layers and with less fan and the lower layers are closer to the heated bed so of course one would assume it's related to one of those 3 things.
Fan failure would explain everything - some fans won't spin at all until you get to 100% fan which would be a few mm up from the bottom. So check that your fan spins even at 50% fan setting. PETG doesn't need as much fan.
inoffensiveLlama 0
i dont have teflon in my hot end. so i dont think it has to do with that.
i just started a new print and the fan is going at 50% and doesnt wait till i reach 100. so i dont think that is causing an issue either.
i try printing with only 3 bottom layers now, so i will get to the part with the infill quicker... i will post an update as soon as i can see a result.
