14 hours ago, Smithy said:Strange, it should be ok when you set In Cura the same material as you have selected during material loading,
Are you sure that the message comes from your currently sent print job? Nothing else in the queue?
@Smithy Thanks for your comment, it was in the right direction. I never knew there was a queue within Cura. Apparently there was indeed a file in there that was sliced with the wrong profile. I emptied the queue and it is happily printing again. Thanks a bunch!
Smithy 757
paxpring 4
Thanks Smithy for your response. Is there a way to see what's in the queue?
