A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,144
There should be 6-7mm between the aluminum uprights and the bed.
1. You could try completely loosening the leveling screws, push the bed to the left, and then tighten it back up and re-level.
2. Drill additional holes in the uprights and move the power supply outboard where Creality should have put it.
3. Put a finger full of grease on the area where it's scraping and say "Good Enough!".
