I don't see any configuration folder.
In the meantime I did have to make another json file to replace the missing one and it does work now. There is a file with the same name, no ext in the old 4.6 folder in the user/cura folder but it is not ascii. Cannot read it with notepad correctly.
nallath 844
No. The old files are still there. If you can zip the configuration folder, I can have a look at what is going wrong.
