Hi geert_2,
thanks for your kind answer. Now i'll try to answer your question.
The metal parts can reach density values near the base material. Just as an example, 7,7 g/cm^3 compared to 8.
The green parts requires debinding and sintering processes, that we outsourced to a proper company.
Unfortunately, the shrinkages are not always constant and they are definitely influenced by process parameters. Just to give an idea, 16/17% in X and Y axis; around 20% in Z axis.
I attached an image of green and metal part.
geert_2 462
I am not using the latest Cura-versions, so I don't know if this is possible in Cura. (We will leave that question for others to answer.)
But a trick you could always try, is to put some tiny dummy objects left and right of the real object, but a bit lower. Then those dummies touch the glass, and your real object is floating a bit higher.
Like these two tiny strips:
Ps: how does this filament compare with real metal (machined)? What post-processing is required, and how do dimensions change (any shrinking, bending, or non at all)? If possible, could you show photos of the print, or of a test-print, before and after post-processing? I haven't seen much people on the forum here with experience in metal-printing, so it might be a good idea if you could share yours.
