Posted · Cura is not slicing at all
Guys, if you just post a message that slicing is not working, what do you think who is able to help you.
So, if you expect help from the community, write a new good post, explaining what is exactly not working, what you already have tried and if needed post some screenshots. Otherwise nobody is able to help.
And @bivai it also doesn't help if you post in several threads, that you have a problem without explaining, so please stop that and open a new thread which explains your problem.
  • Like 2
  • 3 weeks later...
I think every model has a blue line around it.
Usually when Cura refuses to slice there is a problem with the model, or, the model + skirt/brim/raft didn't fit the printable area of the build plate.  There is usually a pop-up to tell the user that there is a problem.
    We have an article on the github wiki wrt the things that we need to diagnose issues. You can find that list on https://github.com/Ultimaker/Cura/wiki/Reporting-issues
    Please report issues on github, since that is the place that we use for that. A forum isn't really suited for it.
