19 hours ago, GregValiant said:I have had some success (depending on part geometry) using support blockers. Set "Per Model Settings | Modify settings for Overlaps" differently for the blocker. You can add walls or change the infill density to 100%.
I suppose you could bring in a 2nd custom shaped model and use it as the blocker. I haven't had to do that yet but off the top of my head it sounds like it should work.
If you use em to change settings, they aren't quite support blockers anymore (but modifier meshes) https://support.ultimaker.com/hc/en-us/articles/360013370140-How-to-adjust-print-settings-of-a-part-of-my-model-in-Ultimaker-Cura
There is also a (paid) plugin that can do all kinds of automatic magic with them: https://www.tetonsim.com/smart-slice-for-cura
GregValiant 1,246
Longtoke 25
This sounds like a possible solution, thank you. Even being able to place a cylinder or cube in a section of my part resulting in a different infill would suffice. Going to have a tinker with it now, will update accordingly.
