Hi gr5, thanks for your answer! That is also what I tried but the result on an UM2 was that it asked if I would like to override the UM2 settings and when I said Yes it just moved the X- and Y-axis around without printing and without moving the Z-axis.
Maybe it has something to do with the difference between the UM1 and UM2? In Cura I compiled the Gcode with UM2 settings and then removed the unwanted layers and adjusted the number of layers at the beginning of the file.
I will try the same thing on the UM1 tomorrow.
gr5 2,070
I did just what you are asking once by hand - I hand edited the gcode and just deleted the upper layers that I didn't want.
